straightening out horizontal stab
Hello,
I just completed sheeting my horizontal stab with 1/16th balsa over 1/4" balsa framing. I used yellow wood glue, and weighed it down with 60 lbs of weight. When I went to check it out later it has a slight bow to it. The work bench it perfectly flat. What would cause this, and how would you correct this. It's very disappointing that you think you have every perfect, and it doesn't come out that way. Thanks in advance.
Regards,
Pat
