ORIGINAL: SAB
tIANci, why not try a 18 x 8 - should be about the same pitch speed on 10S as the 18 x 10 is on 8S
I have a Wind 110 - standard Hacker Motor, 18 x 10, 8S. 10 flights so far & flies much better than my Angel 50.
Steve
Interesting suggestion ... most interesting. Perhaps since the 4S 4,000 mAh packs in HC is cheap I might as well go get some. Only issue is, if the plane goes to that Happy Flying Field in the sky, then what do I do? Get another Wind 110!!!! hehehehee ... thanks again ... will punch in some numbers into MotorCalc.
