RCU Forums - View Single Post - Problems With My New Trainer Plane
Old 08-04-2009 | 01:06 AM
sportrider_fz6's Avatar
sportrider_fz6
Default RE: Problems With My New Trainer Plane
check your antenna wire, is it coiled?, cut? on your engine do you have the thrust washer on it between the case and drive hub? I'll second RCKen on the fuel system, check for leaks, pin holes in the fuel lines, and check the nipples on the needle valve. I just replace a needle valve assembly on one of my LA's it had a small crack and was sucking air.
