okay first off here's the deal...
old style tmaxx
XTM 21 conversion with pipe
RPM wide maxx arms
Omega 15% fuel
RRP hardened diffs
RRP forward only conversion
stock tmaxx tires and wheels
72 tooth RRP steel gear
stock clutch and bell
now I have flown planes for years and I am a mechanic/engineer by Profession and have sucessfully ported and polished anything from a bigblock chrysler440 race engine down to my most recent TRX 15 pro that is a screamer as well.....
I am accustomed to tuning glow engines and Think the high and low needles are right the mid was left untouched as instructed...
the 21 has only been up to 268 degrees one time and instantly shut off (verified by temp gun)
I broke it in quite well follwing as best I could since it came with two entirely different methods( one by OFNA and one by HYPER)
I chose the Idle method in which it causes the carb to sweat due to the rich condition and slowly leaned it out after several tanks.
now it Idles fine,starts fine and screams all the way through second gear,however at the upper 2/3rds of first gear I hear this high pitched chirping hiccup that refuses to go away until the rpms drop when it shifts to second gear.....
I have tried it all, anybody have any Ideas or similar problem......
I am beginning to think XTM's pipe outlet may be too small because the engine turns faster at the upper end of first then any part of second hence lack of exhaust flow???
please help.........
Ohh I forgot to mention that on rough gravel I cant get it past this chirping/sputtering stage to shift to second gear, it will only hit second on the pavement.......
