ORIGINAL: jonlowe
The stock crank can and will break at the rear of the intake port window from a sharp machining edge. I radiused the sharp corner with a Dremel and polished it. I had three break in one year using an APC 18.1x10W. All three had exactly the same failure, and the pieces were so matched they would almost intechange with each other. I started radiusing the port after that, and stopped using that prop at the same time, and had no further failures. The 18.1x10W is a heavy prop, which I think exacerbated the problem. The 17x12W turns out to be a better match for the engine anyway.
Like this Jon ?? . . and guess which prop !
I really like the 18.1 x 10W . . it flies slower with better throttle control. It also has slower downlines. I am running an Aeroslave pipe though . . so may be the difference.
Cheers, JB
