RCU Forums - View Single Post - Sputtering idle on OS 55AX.
Old 08-04-2009 | 07:13 AM
Sport_Pilot's Avatar
Sport_Pilot
Default RE: Sputtering idle on OS 55AX.
I'd say the idle mixture is rich. If you are using a check valve in the muffler pressure line, remove it. I agree with freaking fast. A kink in the muffler pressure line could act like a check valve not allowing the tank pressure to drop right away causing the mixture to be rich until it does.
