RE: Needed: needle valve extension
Yep, piece of music wire from the LHS or an old allen wrench (small) you don't mind giving up. Just about anything small and stiff that has a 90 degree bend on the end or can have one put in it. Could also solder a knob there if you have the skill and install after the engine is in the plane.
