RCU Forums - View Single Post - Needed: needle valve extension
Old 08-04-2009 | 05:21 PM
shd3920
Default RE: Needed: needle valve extension
I see where the set screw used to be (where can I get another set screw? Just found out it's missing)
But I can't follow where you are saying to put the music wire/allen wrench. I see a small hole at the front of the needle valve, does this have anything to do with what you are suggesting?
