RCU Forums - View Single Post - Needed: needle valve extension
Old 08-05-2009 | 05:12 AM
GaGeeBees's Avatar
GaGeeBees
My Feedback: (23)
Default RE: Needed: needle valve extension
ORIGINAL: Gray Beard
You may want a bigger hole in the side of the fuse/cowl!! Think vibration and torque!!!
I like to slip a length of fuel tubing onto the shaft of the extension if I'm going through wood like this application. On fiberglass cowls, I use a rubber grommet. Both work well.
