RCU Forums - View Single Post - Smoked motor - suitable replacement?
Old 08-05-2009 | 08:46 AM
ryan_t888's Avatar
ryan_t888
Default RE: Smoked motor - suitable replacement?
Does your hull use a prop? What size in diameter?
The problem is you are asking a lot from that motor to attain the speeds you are getting from it. It simply does not have the mass to dissipate the waste heat produced. A larger motor with slower RPM's would be better suited.
I would also recommend picking up an ESC for you receiver to power the motor. This will result in greater efficiency and control.
Ryan
