RE: Spektrum Operation
The Quick Connect firmware causes the rx to come back online using the same two frequencies it was on when it lost power either to you changing a battery or a lower power brownout in flight. It will continue to come on with flashing lights until you cycle the power on the tx and cause two new frequencies to be selected and the rx linked.
Did you turn off the tx while changing batteries?
