RCU Forums - View Single Post - Smoked motor - suitable replacement?
Old 08-05-2009 | 09:11 AM
anders_r_r
Default RE: Smoked motor - suitable replacement?
Ryan, thank you for your response! And thanks for all the info you give in the thread "Choosing an Appropriate Fast Electric Setup"!
The hull uses a 3 blade plastic prop, 35mm in diameter.
Could you, or others, recommend a specific motor that will be suitable?
Also, what is recommended, direct drive or a motor with a gear box attached?
I would like to avoid ESC, since I use a simple rc that is taken from the cheapest rc car I could find (approx. 10USD).
Anders
