RE: Powermax Problems..
i was in the midst of trying to edit it when my ISP kicked out, and got it fixed but not before you posted.......it's LESS onboard weight. you don't need to use the solenoid so you save the weight of it as well as the onboard tank, all you need is the 3-4mm adapter and the check valve on a pig tail.
