ORIGINAL: iflyg450
...... and I was wondering if more spaceing between the leadout changes anything. ....
.....How long should the leadout extend past the wing tip?
-Jason
Spacing of the leadouts doesn't really have much effect - where they are located wrt the CG is more important
The leadouts should be long enough that full control doesn't try to pull a line clip through the wingtip - in other words, if you pull a leadout to full control one way, then pull the other to full control, neither one should "Bottom Out" on the leadout guide or the wingtip.
