RCU Forums - View Single Post - taking off
Thread: taking off
Old 08-05-2009 | 01:38 PM
jetmech05
Default RE: taking off
It's a Nexstar.....I have taught with three different nexstars from different years and they all pull right somewhat......I have found that if you lift off a bit sooner it is not so bad...but you risk a stall, as a beginner......if you mess with anything on the whells or trim then you have to put up with what you just put in on landing...now you pulled right on take off but were fine on landing...try a couple of washers under the right side motor mounts......
