RCU Forums - View Single Post - Prop Composition
Old 11-13-2002 | 07:48 PM
HGU 34
Default Prop Composition
In very general terms, wider chord propeller blades were intended to be better suited to four strokes with their higher torque and also were intended to work well with longer stroke 2 stroke engines that also tend to have a little more torque than the average short stroke two stroke engine.
As an aside, two bladed props tend to offer better cruise/top speed performance due to their improved aspect ratio while three blade propellers tend to offer better low speed performance due to better disc loading at lower speeds.
In general, R/C propeller efficiency has been pretty low - maybe 50% - compared to a full scale aircraft expectation of 80% prop efficiency. However the newer generation propellers and APC's new props in particular are reported to have an 80-85% efficiency. This means a lot more performance. So you really need to just experiment with several types as well as with pitch and diameter until you find a prop that works best for your particular aircraft, engine and type of flying.
