RE: Echo 50cc Short Block Conversion - Seeking Advice
KD,
I think the best way to get all of your parts true is to make a mandrel that has the same taper as the crank.Then mount the hub and true it on the mandrel.Or you can disassemble the engine and use the crank as the mandrel and true it all together.This is how I do mine.
