RCU Forums - View Single Post - Powermax Problems..
Old 08-05-2009 | 08:59 PM
  #31
Edgar Perez's Avatar
Edgar Perez
My Feedback: (13)
Default RE: Powermax Problems..
ORIGINAL: Pete737
ORIGINAL: Edgar Perez
ORIGINAL: Pete737
Wish I could go to the green bottle but my Jet Central wont light on it. Tried it a handful of times, It wont pop []..
Pete
Work with Eric to get the right parameters.All my Jet Central light easily with Propane.
Edgar, I have a older version Falcon. I don't have the option to regulate gas flow, Only glow power, speaking of which I have tried every reasonable setting with no success. I have had a number of guys look at it as well, Puzzling..
Pete
Pete, I also got the old ECU. I get Propane starts all the time using [link=http://www.dreamworksrc.com/catalog/product_info.php?products_id=774]this valve[/link]. Just used the lowest setting (one click only). This gives like 12-15 PSI. No restrictor needed.
If the plane has long line for the gas (e.g. big plane like the Eurosport), then may need to make sure not too much wind get into plane, so align 90% to the wind.Good luck
