RCU Forums - View Single Post - Stackeddeck's Problems- continued...
Old 08-06-2009 | 05:28 PM
stackeddeck
Default Stackeddeck's Problems- continued...
Haha sorry I was tired of clicking to page 3..and I'm ADDI need a clean page (just kiddin ha)
drumroll....ratatata
Im getting dern easy vee if it kills me..
go to zippkits.com for hull (easy vee) 60 bucks
46 inch..
http://www3.towerhobbies.com/cgi-bin...LXWPW0&P=6 will this radio work for it? 80 bucks
http://9x4br.64n2f.servertrust.com/P...BUILDERSPECIAL
299.... it will work...
<ul>[*]23cc 4-port factory modified air-cooled w/ clutch and 4-point mounts (14,500RPM @ almost 3HP) 23cc will be big enough? to go say 35 mph?[*]Factory canister muffler[*]XP2P composite molded drive (Can be used both surface or sub-surface)[*]Drive cable w/.250 dia. Stub end[*]12" shaft tube w/ Teflon liner[*]75 mm prop[*]Radio box w/ pre-cut servo tray and lid[*]28 ounce gas tank[*]Throttle cable kit[*]Radio box seal kit[*]Steering rod kit[*]SS adjustable trim tabs (pr.)[/list]total so far 440.....$$$$$ ahh
http://www3.towerhobbies.com/cgi-bin...8&amp;I=LXUK84 servo? Ineed 2? 2 of the same kind? will this work?
wood cement for putting kit together? http://www3.towerhobbies.com/cgi-bin...LXHE31&amp;P=0
epoxy? http://www3.towerhobbies.com/cgi-bin...LXPT47&amp;P=0
am I missing anything?
tell me what you think.....
will this make a slow boat? bad boat? decent boat? awesome boat!?
