Servo tray installation:
Cut the servo tray from a piece of 3mm ply wood according to the template supplied with the kit. Test fit your servos.
Servo Tray
Now mark the hole for the mast tube on the main hull deck. Carefully drill the hole and test fit the deck, with the servo tray laid in, the rudder tube protruding the tray about 5mm level to water line. Sand the edges of the servo tray down until smooth fit without deforming the hull.
Glue the tray to the hull with epoxy, temporary tape the deck to the hull to ensure that the hull does not get deformed.
Mast tube hole marked and drilled
Servos test fit
Servo tray epoxied to main hull
Deck temporary taped to main hull to prevent distortion
Next I will assemble deck and main hull
