RCU Forums - View Single Post - ax 55 problems
Old 08-06-2009 | 10:42 PM
jimmyjames213's Avatar
jimmyjames213
Default ax 55 problems
well my ax55 will idle all day and transitions great (1 flip starts) but their is this one spot, just past idle but not more than 1/3 open where the engine seems to run fine then all of a sudden dies.
this has caused way to many deadsticks for my likeing and due to my luck, this is where i run my engine when i am doing harriers (mojo.40)
i had this problem with a os fp 40, and seemed to solve it, but that was with an airbleed carb and not a twin needle. (high end was to rich while low end was a hair to lean, after i fixed that the engine runs like a top, 1 flip starts as well)
this engine is on a profile, so i can see the lines/tank. the engine likes to die when its 2/3 full (8oz).
the fuel was foaming but i thought i fixed the problem, ill doubble check to make sure i did.
has anyone else had this expierence? run fine but dies at one setting (1 click up or down and it wont die)
the engine is still breaking in with maybe 1/4 of a gallon through it.
