RCU Forums - View Single Post - ST-90K with Perry Pump
Old 08-07-2009 | 06:53 AM
jstanton's Avatar
jstanton
My Feedback: (14)
Default ST-90K with Perry Pump
I have a perry pump I plan on putting on a ST-90K. I am doing this because I want to put the fuel takl over the CG of the pusher Jet I am building. I started to set it up according to the instructions I got on the Perry web site. It shows a back fill line set up on the fuel system. It wants you to install a T fitting between the pump and carb and run that line back to the line that feeds the carb right at the tank. I thought this was not right so I called Perry for some help. He told me that diagram on the web is for a car setup. He told me to use a 3 line setup on the tank and run that line from the carb back to the fill line at the tank. This made more since to me and this is how I have set it up. I was hoping to hear back from some of you on how this setup works
