ORIGINAL: TedMo
You're really trying to push your luck. It would be quicker to just stomp on the whole thing. Plane looks good and for the sake of new bat. why destroy it. By the way if TX bat only hold charge for 1 hour or less heave them they should last at least 3 hours if any good.The radio you have is a good one but get new ba t. for Tx and Rx. Or stick to boats and cars.
Well this isnt all going to happen right away....im not going to take this out to fly anytime soon......i need to do a bit of fixing up with it anyway...the covering on it has a rip in it here and there...i need to CA the hinges for the rudder and elevator back on the tail section (you can just pull it out by hand right now)....Im going to have to replace the power switch for the Rx since its always on despite what position its in....Ill need to tune the motor again since it hasent been run in a while...probably needs a new glo plug too...I was just asking about the batteries since those are the things im not sure about....i know what to do with the rest of it....
If you really think i should replace them both, then i will...im just trying to avoid as many costs as possible as this plane isnt the only thing my money is going to right now....
