RCU Forums - View Single Post - Calmato trainer 40
Old 08-08-2009 | 02:15 PM
ChuckW's Avatar
ChuckW
Default RE: Calmato trainer 40
Exactly, the prop should make the plane fly how you want in the air. Do you like the way it flys?
If so, try adjusting your idle speed. If the plane still wants to roll when the idle speed is correct then maybe look at adding some friction to the wheels with something like fuel tubing between the wheel and collar. Be careful not to add too much resistance or you'll just create a new set of problems.
