Beam Assembly
Take the 6mm carbon tubes out of the box and insert into the holes in the main hull. Now stick the other end of the tubes into the holes of the floats. Align the three hulls to be parallel, the centerline of the main hull 280 mm apart from the centerline of float centerlines left and right. Mark the positions and glue the tubes into position with epoxy resin. Double check alignment and allow to cure.
Tri with beams installed
Your Trimaran is now ready to install your rc equipment and rig.
