RE: OS 140RX Need Help
I have not done anything other than adjust the HS needle...
I'll try replacing the main bearing...
Dennis, Im caught between getting this going and/or trying to get the Titan airborne. If I get the Titan going and you want the plane, I may wish to use the Titan until I get the Temptation sorted out...
Thanks for the help...
I'll try to replace the main beiring and see wear it goes...Is fuel leaking out of the carb a normal thing?
Larry...
