RCU Forums - View Single Post - OS 140RX Need Help
Old 08-09-2009 | 09:15 AM
DRC1
My Feedback: (10)
Default RE: OS 140RX Need Help
ORIGINAL: d_bodary
Well the stock OS# is 46030008
The CFI bearing # is 29430010 This is the one you want if at all possible. If you are using the unsealed one it will work just won't last any where near as long.
As far as changing the bearing it is the same as replacing any typical OS bearing.
The one big difference is the piston ring. it has to be lined up with the pin in the ring groove otherwise the ring will not compress enough to put the sleeve over the piston.
Leave the hammer in the toolbox. if you have it lined up correct the sleeve will smoothly go over it. It's a PIA but after two minutes you should have it.
As far as the needle valve go on Tower's website Look for the parts for the OS140RX and they show the two different needles. should be able to tell which one you have by the pictures.
One other thing the key for the prop washer only goes in one way the flat side to the engine.
<div style="margin: 0in 0in 0pt"><span style="color: navy; font-size: 10pt">I have the stock needle&hellip;.</span></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"><span style="color: navy; font-size: 10pt">My spare main bearing is a Boca Bearing&hellip;P/N 6904Z and it is either shielded or sealed&hellip;</span></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"><span style="color: navy; font-size: 10pt">There appears to be no detectable play in the main bearing currently installed in the motor&hellip;</span></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"><span style="color: navy; font-size: 10pt">My strategy is to flush the pump first and see how it responds&hellip;If no go, then replace the main bearing&hellip;</span></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"><span style="color: navy; font-size: 10pt">Thanks for all the help, I will keep you posted&hellip;Hopefully we will get a few practice flights in yet today&hellip;
Larry</span></div>
