RCU Forums - View Single Post - Futaba mixing for multiple servo Ailerons and Elevators
Old 08-09-2009 | 09:38 AM
Walt and Sage's Avatar
Walt and Sage
Default RE: Futaba mixing for multiple servo Ailerons and Elevators
One servo goes on aileron and one on flaps and turn on FLAPERON...
If using two servos on the elevator, the ONLY place is the elevator spot on the receiver...
You will need to use a reversing "Y" or program reverse into the servo..
Myself , I would never use a "Y" on a GAS motor for the elevators...
It has been awhile since I have programed a 6 chanel but I think you can
program the flaperons with the elevators on a switch to do some wild 3D..
BE CAREFUL cause you can get into flat spins all the way into the ground with
the switch ON...
Walt
