ORIGINAL: Gorgok
I think the part he is more concerned about is the fact that it is at 50% throttle at center, and idle at the brake position; while he would rather have it idle at center and at brake position. Programming the TX end points or throttle curve could probably do that, but i don't know anything about the programming of that TX.
Right.
Maybe I should use a car/buggy linkage and set it up the way these are with the servo saver springs. I could get a servo arm to give me full throttle at full back trigger and idle at 50%. I can dial it in with the endpoints.
Is there a way I could do this with just the brake settings and not worry about the spring?
