RCU Forums - View Single Post - Gas Conversion
Old 08-09-2009 | 10:07 AM
Ralphbf's Avatar
Ralphbf
My Feedback: (27)
Default RE: Gas Conversion
ORIGINAL: coralcape
Perhaps your rich condition is caused by the walbro carb. I have a corsair with a homey 45cc conversion, that does the same thing (goes rich in the air). I've just finished tapping the plate over the metering side of carb and plumbing a line to dead air. Will find out Mon. if it works. Good luck, red
This is a standard fix for going rich in the air.
It really helps with transition also.
The new tube from the metering plate goes inside the Fuse.
Good Luck
