RCU Forums - View Single Post - How about SIG rascal 40 as trainer
Old 04-13-2002 | 01:42 AM
crossed thumbs-delete
Default How about SIG rascal 40 as trainer
Hello High Hover.
I recomend a LT40 as a trainer. I have both and the 40 Rascal has bolt on wings. If and when you put a wing tip in the Rascal may pull the bolts through the wing and cause cosiderable damage.
However the LT uses rubber bands to hold the wing on and you have some give when the wing tip makes contact with the ground, therefor reducing the posibility of damage to the plane.
Sometimes I fly the LT because I want to practice landing in crosswind conditions. Helps with eye hand cordination.
Remember there are two knds of aircraft. Those that have and those that will..Crash.
Good Luck
Crossed Thumbs
