ORIGINAL: dasintex
I've been told and read that if you use 2.4ghz Radio equipment, that distance between Kill Switch and Receiver is not as important as it is with 72mhz Radio equipment? is this true? and if it is true than your Switch Placement choices increases.
Yes it is true, a 2.4ghz radio system is a lot less prone to radio interference than one on 72mhz, but that does not mean that common sense and good judgement should not prevail as 2.4ghz is not the Holy Grail and can have problems .
Karol
