RCU Forums - View Single Post - Throttle Servo Setup
Old 08-09-2009 | 01:51 PM
Gorgok
Default RE: Throttle Servo Setup
With end points you should be able to tell the servo that hitting brake or keeping it at center is the same thing. If you could adjust the throttle curve it would look like a slope that has a flat spot at the tail end. Sort of like this: \__
