RE: Programming Futaba 6EX for an Axe 400
Thanks so much, Dick. That is all good info. I printed out the gyro setup info and will go through it when the battery is charged up.
To add a separate Rx battery, all I have to do is clip the red wire on the ESC throttle channel connector, and use the battery port on the Rx, yes?
