ORIGINAL: Mustang Fever
Thanks so much, Dick. That is all good info. I printed out the gyro setup info and will go through it when the battery is charged up.
To add a separate Rx battery, all I have to do is clip the red wire on the ESC throttle channel connector, and use the battery port on the Rx, yes?
That is correct but don't cut it. Use the tip of an Xacto knife to lift the little tab in the center of the connector then slide the wire out, double it back and tape to the other wires.
Keep in touch.
