RE: Downline Braking : ESC set up query
In both the Master and Spin (Hacker/Jeti) esc you can set the level of braking. Interestingly, too much brake can be less efficient than the "right" amount of brake (probably the prop blades turn too slow, with stalled airflow..). In my case, Hacker C50 XL13, the sweet spot is between 20 and 26%.
