RCU Forums - View Single Post - Tips?
Thread: Tips?
Old 08-10-2009 | 09:35 AM
speedy72vega
Default RE: Tips?
foehammer, when you do maiden it, just try to get as much altitide as possible right away, that way you will have room to correct if anything is out of trim. Once it's up, just practice steady level flight, and slow easy turns. It's not like the Super Cub, with aeilerons, you want to start the bank using the aeilerons (right stick on the tx) and then add some up elevator to bring the plane around. You will have to come out of the bank with opposite aeileron, as the Corsair doesn't self correct like the Cub. You can use the rudder to turn (left stick on the tx), but you will want to learn how to use the aeilerons and elevator to turn for the most part.
