RCU Forums - View Single Post - Downline Braking : ESC set up query
Old 08-10-2009 | 02:38 PM
Capiche
Default RE: Downline Braking : ESC set up query
I am not sure I follow.
You suggest setting the brake control on will enable me to set a low rpm at idle which will avoid the airflow speeding it up ? Whereas with the brake off then at low power the airflow will cause the motor to rotate faster than the ESC is commanding ?
