RCU Forums - View Single Post - ax 55 problems
Old 08-11-2009 | 01:02 AM
DarZeelon's Avatar
DarZeelon
Default RE: ax 55 problems
ORIGINAL: jimmyjames213
...Then I went to that one spot, it loaded-up a little so I leaned my high-speed a few clicks and it was all good from there (I set my high-end a little too rich most of the time) I haven't had a dead-stick in 5 tanks.
JJ,
You are probably just a bit lucky and luck has been known to run-out...
Leaning with the high-speed needle, to overcome a rich condition at part-throttle, will only make the engine leaner at the top-end, without affecting the low-end...
If it was set too rich there, it will work only there; and there is no chance it will affect the mixture at less than 75% throttle.
If it did help somehow, there is something seriously wrong, defective, or dirty with your carburettor.
