RE: Programming Futaba 6EX for an Axe 400
The set up sounds correct now. The slight drift in HH can now be corrected with a beep or two of rudder trim while in HH but will drif when it is off. That is about as close as you can get.
Glad you like the AXE 400. It is a good little bird.
