RE: New HOW TO Posted: How to Install Robart Hinge Points
Hi Redback,
The best way to remove a Robart hinge with the least amount of damage is to use a sharpened brass tube slightly larger than the Robart itself and install the brass tube into a cordless drill. Then, carefully drill into the wood around the hinge and wiggle the hinge out after you are done with the drill. Hope that helps.
Happy flying and soft landings!
