RCU Forums - View Single Post - Engine bogs down past half throttle!
Old 06-26-2003 | 11:32 PM
renne321's Avatar
renne321
Default Engine bogs down past half throttle!
If its a single needle carb and you turned the needle more than 1/8 to the right then the engine will overheat a begin to die. Try to set the needle back to its stock position and see if it runs fine from their. Then you can make your adjustments.
