RCU Forums - View Single Post - Engine bogs down past half throttle!
Old 06-27-2003 | 12:29 AM
rcfoolz
Default Engine bogs down past half throttle!
Check the air filter then if you have a fuel filter check that. if both of those are OK, then is sounds like you have the high needle way to lean. I had a motor like that and it confused me. It sounded like it was starving. I richened up the motor and it ran fine.
