RCU Forums - View Single Post - Bad USB Interface Cable
Old 08-11-2009 | 06:42 PM
jon595
Default Bad USB Interface Cable
Hi,
I've had AFPD since it came out, upgraded my copy of AFP to get it. After so many years it seems that the cable has finally died. The error that I get is "AFPD has located the USB Interface cable but is unable to either find a transmitter connected to the USB Interface or a joystick connected to the gameport". I cut the heatshrink away to check for a broken connection, and use the adapter to plug it into my old JR 10X transmitter. Well I had cut the ends off the cables and soldered them directly because the plastic housing rotted away. Anyway, I cut the heatshrink off of that and it has good connections there as well. My version number is 1.11.07.21, serial number is 7064C792. I would like to get a new USB Interface cable without having to purchase the whole package.
Jon Tate
