RCU Forums - View Single Post - Saito 180 with perry pump
Thread
08-11-2009, 08:41 PM
6
dmesecher
RE: Saito 180 with perry pump
]The low and high speed are set to break in settings . This engine has one tank ran through at the 4000 rpm then on second tank went to adjust hs and throttle up and found it starving for fuel, or that is what it sounds like...I will attach a pic. The preassure line origanaly had a tee fitting for draing the excess oil. I put on a solid fuel line to see if this was my issue and still had the same outcome
Reply
Like
dmesecher
View Public Profile
Send a private message to dmesecher
Find More Posts by dmesecher
View iTrader Profile
