RE: Saito 180 with perry pump
Some observations. The pump looks like an older one; I have read here on RCU that they can go bad with age sometimes. Because you are using the 2 stroke pump if you put a T in the pulse line you will be loosing the pulses. The 4 stroke pump works on vibration and might work better for what you are doing.
