RE: Saito 180 with perry pump
You can only use the regulator pump on smaller four strokes, as TFF said you lose some of the pulse with the tee. Also you lose them if you do not use hard line, soft line expands and reduces the pulse. The four stroke pump is what you need, or a regulator.
