RCU Forums - View Single Post - Attaching antenna to plane
Old 08-12-2009 | 01:40 AM
  #36
jimmyjames213's Avatar
jimmyjames213
Default RE: Attaching antenna to plane
for profiles and some kits i run the antenna wire out the wing. on other planes i glue a small, 2-3in long, piece of nyrod/small tube/ect to the bottom of the fuse. then run the antenna along the bottom of the fuse then through the tube. you could also glue it to the top of the tail and run it through that way.
