RE: decathalon engine mounting
Gidday mate,in an effort to extend your enjoyment and flying hours could i add the following.It's a very strong kit with the struts fitted correctly,keep an eye on the leading edge wing mount too,it gets larger over time.As for flying one they are quite docile as long as you know where you want to go,if you dither a bit about that the decaff will instantly take over and do all of that for you,sunday cruiser it is not tho should be light and fairly slow with the 46,i run a saito 82a in mine.Good luck.
