RCU Forums - View Single Post - weight VS stability
Old 08-12-2009 | 11:25 AM
  #31
Allfat's Avatar
Allfat
Default RE: weight VS stability
First figure out where the weight needs to go to balance the plane by just setting the weight on the outside of the plane and seeing if it balances. Then, once you know where it goes to balance the plane, put it there permanently, either inside or outside the plane. Inside looks better, but outside functions the same and is easier to install.
